It is currently Sat Aug 23, 2025 2:42 pm
PostPosted: Tue Nov 29, 2016 10:30 am
First name: Lou
Last Name: Moritz
City: Fords
State: New Jersey
Zip/Postal Code: 08863
Hi Guys,
New to the forum, intro is here: viewtopic.php?f=10101&t=48602
Has anyone ever made or used Corian as top for a router table?
I can get my hands on a 2' x 3' piece for next to nothing and I really need to upgrade my current router table.
PostPosted: Tue Nov 29, 2016 10:43 am
Last Name: Orr
Have not used it but given how stable it is, and you can rout it, I think it would make a great table top.
Bob
PostPosted: Mon Dec 12, 2016 3:35 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
It will make a really nice top, but don't overestimate its stability ... I assume you will be using the standard 12mm thick stuff ...I would reinforce as much of it as possible with 3/4" plywood glued on with contact cement, just leaving enough for the aperture. 2'x3' supported only at the perimeter will sag over time.
PostPosted: Tue Dec 13, 2016 12:35 pm
I used corian for a router table top (still have it around somewhere) I made the plate the router mounted to out of corian as well. I made it large enough to lift out with the router attached. No real problems with it. Fences had to be clamped rather than screwed down. I did away with the router table to save space and mounted a router base to the aux. table of my tablesaw.
PostPosted: Tue Dec 13, 2016 1:04 pm
First name: Lou
Last Name: Moritz
City: Fords
State: New Jersey
Thanks for the tips and heads up Guys [:Y:]
cron
